My 2003 Golf is having a problem with overheating. I am able to drive the vehicle around town for extended periods of time at speeds under 70 mph with no problem. However, when i drive on the freeway at higher speeds in fifth gear the vehicle will overheat. But when i slow down to about 50 mph the temperature drops back to a perfect level.
Also, the heat doesnt work anymore either. There are no leaks and the coolant level is at a perfect level. Is this a thermostat issue, waterpump, or something else? Thank you!
Oct 7, 2009 at 2:10 AM
