2003 Volkswagen Golf brake lock
64,000 MILES • 4 CYL • 2WD • AUTOMATIC
BIRCK42
2 days ago i noticed a grinding noise coming from my left driver side wheel when I applied the brakes. Today I was leaving my house and the wheel locked. It appears that the brake will not disengage the wheel. There is also a flood of brake fluid now pouring from the wheel. I have no idea what is happening but sounds like a cylinder issue. Can you help?
Aug 4, 2009 at 8:08 AM
DOCFIXIT
  • 18,828 POSTS
Well the grinding was pad completly worn out now metal to metal with rotor. piston in caliper came out and locked up wheel. You went from a simple pad replacement to an expensive repair pads, rotor, caliper
Aug 4, 2009 at 8:29 AM
