Check engine light on with code p0103 code
234,000 MILES • 4 CYL • FWD • MANUAL
SPARKS1984
hi, my engine light is on and i checked it and gave me p0103 code. looked it up and replace the mass air flow sensor, and still gives me the same code.
Jan 22, 2010 at 3:09 PM
SQM
  • 6,383 POSTS
The code P0103: Mass or Volume Air Flow Circuit High Input
One of the reasons for this code can be triggered is due to a leak in the air intake tubing.
Check for any loose connection or crack in the intake tubing.
Another possibility is a faulty wiring to the mass air flow sensor.
I have attached diagrams as well as the leak test procedure below.
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
Dec 3, 2021 at 1:36 PM
