2002 Volkswagen Golf hand brake /and how to fit rear pads l
2002 VOLKSWAGEN GOLF
48,000 MILES • 4 CYL • 2WD • AUTOMATIC
ZAHID TARIQ
hi guys can you please how to adjust the handbrake on a volkswagen golf i.6cc automatic,year 2002 model ,and also how to push rear caliper piston back home to fit new pads .thank you
Aug 22, 2009 at 9:49 PM
DUBTECH
  • 159 POSTS
The adjustment for the parking brake is on the lever assembly in the center console. You may need to remove part of the console to access the adjustment rods/nuts.
There is a special tool designed specifically for depressing the piston in a parking brake equipped caliper.
You need the screw the piston in clockwise as it is being pushed in. It can be done with pliers and a standard piston compressor, but you have to be very careful not to damage the piston dust boot.
Aug 24, 2009 at 2:52 PM
