2002 Volkswagen Golf engine vibrate at idle
2002 VOLKSWAGEN GOLF
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAEEFAN
engine vibrate at constant interval every 3 sec. the RPM drops (100RPM) momentary and coms back up.
it is visible looking at the engine or the RPM meter.
Dealer claims he can not reproduce the problem.
PS. it sort of disappear when the engine reaches normal operating temp.
Aug 17, 2009 at 2:56 AM
DUBTECH
  • 159 POSTS
Vacuum leaks are very common on these cars and will cause the same symptom.
Look very closely for any broken, torn, or loose hoses.
Even if the plastic boot around your dipstick is broken it will create an intake leak.
Also check for a dirty throttle body.
Aug 17, 2009 at 2:39 PM
