2002 Volkswagen Golf
2002 VOLKSWAGEN GOLF
107,000 MILES • 4 CYL • FWD • MANUAL
M.PUCUNAS
2002 golf 2.0 has a small amount of foamey oil under oil cap
Feb 6, 2009 at 8:02 AM
VLADGEISER
  • 66 POSTS
Sounds like you may have over filled your oil, most of the time it will burn off an you will be fine, but if it is foaming already you probably need to do another oil change on it just to get all of the oil out and start over.
Be sure to check the oil for contaminants as well as there are other things that can cause this, over filling is just the most common.
Mar 6, 2009 at 3:34 AM
