2001 Volkswagen Golf knocking rear end
2001 VOLKSWAGEN GOLF
72,000 MILES • 4 CYL • FWD • MANUAL
GAZOLEAN
Hi there,i have a mk4 golf 1800 gti turbo,there is a loud knocking coming from the n/s/r wheel area when i go over bumps.Ive been underneath it and there is nothing obviosly loose and no missing exhaust rubbers,maybe a bush but which one.Help me out before i get nagged to death.regards Gaz.
Jan 31, 2009 at 9:12 PM
VLADGEISER
  • 66 POSTS
See if you can get the shocks to bounce, just put some weight on the bumpers; the shocks should go down and come up once. If the car bounces more than once you probably have one or more bad shocks and should replace them, what i see happening is every time you hit a bump one of your shocks is compressing completely and slamming itself against your frame causing a loud thump.
If the shocks are all good, check to see if you have a loose brake pad.
Mar 6, 2009 at 3:40 AM
