2000 Volkswagen Golf door inner panel
2000 VOLKSWAGEN GOLF
98,000 MILES • 4 CYL • 2WD • MANUAL
SAMCRO
how to remove inner panel from drivers door
Jun 22, 2009 at 8:17 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Switch off ignition Insert flat screwdriver in lower partition between panel and grip recess Unclip grip recess upward out of door trim, do not reach into grip depression while doing so, to prevent damage to brace Press locking lug against connector and pull off Unscrew seven bolts Unclip door trim at the sides using disassembly pliers (SST 3392) Lift door trim upward out of window recess Unclip cable guide using a flat screwdriver, pull out bracket and unhook cable hook Disconnect connectors
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_4.png
Jun 22, 2009 at 10:22 AM
