The car is a 2000 Volkswagen Golf 1.8T
The timing belt broke at 54000 miles so the dealership put on a brand new cylinder head. After the new head was installed the car started smoking at idle. The dealership said that it was probably from the oil that got into cylinders when the timing belt broke and that it will burn off. A year later it is still smoking and also has a rough idle.
I did a compression test and the results were perfect. 175psi across all 4. Specs are between 145 psi - 200 psi.
What are the other things it could be and what is the best way to test for each? Thanks for all the help.
Jan 21, 2009 at 5:50 AM
