2000 Volkswagen Golf
NICK_ROD
Engine Mechanical problem
2000 Volkswagen Golf 4 cyl
The vehicle will not start, I sprayed starting fluid & it starts right-up. I checked the fuse it was o.k. I traced & replaced the fuel pump relay & that did not solve the problem. I can't hear the fuel pump running. I can't find the fuel pressure relief valve to check for fuel pressure. Any assistance is appreciated. Thanks
Mar 15, 2010 at 5:59 AM
DOCFIXIT
  • 18,828 POSTS
Good place to check pressure is at fuel filter
Mar 15, 2010 at 7:09 AM
