starter motor not turning?
PIERRE1113
We have replaced the battery and starter motor but its not turning.
Jan 11, 2009 at 2:01 AM
SQM
  • 6,383 POSTS
You could have a inoperative starter due to a faulty relay, wiring or bad starter motor.
First check the relay. It is located under the hood fuse block (see diagram).
Visually check for corrosion and burnt pin(s).
You can also test the relay:
Also check the wire that attaches to the starter and make sure it is secured. A loose wire can trigger no start.
If you have a good relay and good connection then it is likely a bad starter.
Aug 24, 2021 at 3:30 AM
