1999 Volkswagen Golf
MAC TYRE
Shakes or Wobbles problem
1999 Volkswagen Golf Front Wheel Drive Manual 106350 miles
WHEN GAINNING SPEED CAR STUTTERS OR JUDDERS SLIGHTLY OR GOING UP HILL AROUND TOWN AND AT LO GEAR BUT GOES WELL ON OPEN RD
Nov 9, 2010 at 9:40 AM
  • 75,988 POSTS
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Nov 9, 2010 at 9:48 AM
