1998 Volkswagen Golf Drove through large puddles, is my car
1998 VOLKSWAGEN GOLF
181,000 MILES • 4 CYL • FWD • AUTOMATIC
ZALIM
I accidentally drove through large puddles on Christmas Eve and my VW Golf stalled as I was turning into the grocery store. It scared me to death as the person behind me could have slammed into me. I had my car towed to the dealer who eventually identified that an ignition coil was cracked and didn't react well to getting wet. They are recommending I replace it ($400).
I have been reading on the Internet about the damage water causes and now I am very worried about what I've done - I can't sleep. Did I destroy a $15K car in 2 seconds?
The VW mechanics seem to believe that replacing the cracked coil should solve my problem, but I can't help worry that I caused permanent damage to my car that they can't see. Is that possible?
Zalim
Dec 28, 2008 at 2:18 PM
  • 31,937 POSTS
Hi there,
If the engine is cranking over and not firing, this could well be the coil problem, if you ingest water into the cylinders this is when you can do a lot of damage, but normally the engine will not even turn over, make sure that they check the induction for water replace the air filter if it has been wet, i would not worry to much, as i feel that its just an ignition problem you have.
mark (mhpautos)
Dec 28, 2008 at 5:49 PM
ZALIM
Thanks very much. I will ask them to do that.
Zalim
Dec 29, 2008 at 12:15 AM
WAYNEFRASER
  • 21 POSTS
[quote:3271ac179c="zalim"]Engine Mechanical problem
1998 Volkswagen Golf 4 cyl Front Wheel Drive Automatic 181000 miles
Your car is built to withstand puddles . If your ignition system was in good shape the water shouldn,t bother it. I would listen to the mechanics.
Four hundred seems a lot for a coil though.
Zalim[/quote:3271ac179c]
May 12, 2009 at 6:07 PM
