1997 Volkswagen Golf reverse gear
1997 VOLKSWAGEN GOLF
90,000 MILES • 4 CYL • FWD • AUTOMATIC
MR JAKE
when I put my veh into reverse gear nothing happens, no noise etc, but if I give it a bit of gas at about 2000 rpm the veh goes into reverse. Also of note all forward gears are working fine
Jul 23, 2009 at 8:21 AM
DUBTECH
  • 159 POSTS
Very common failure on these cars. Sometimes checking and topping off the transmission fluid helps, but usually requires a new/rebuilt transmission to solve.
There is a trick to increase line pressure, but the fluid pan needs to be removed and a specialized torx bit is needed to adjust the screw. This is just going to buy more time, as the damage/wear has already been done.
Jul 27, 2009 at 3:34 PM
