1997 Volkswagen Golf need an answer
141,000 MILES • 4 CYL • 2WD • MANUAL
KYKY3280
My car would not start earlier today, i held the cluch turned the key and nothing happened, 3 hours later when it warmed up outside it started fine. i drove it down the road and made it a mile and the car would shake and vibrate and wouldnt go when i hit the gas.
I made it home driving really slow, and drove it around the area behind my house. When i leave it idle it shuts off after about 10 seconds. Its almost acting like its not getting gas, but then when i put it in gear and hit the gas the car goes then knocks and shuts down. its only when i hit the gas pedal. i dont know if it has an inline fuel pump and where it would be located on it, and i dont know what is wrong.
Feb 27, 2009 at 6:17 AM
VLADGEISER
  • 66 POSTS
Simple stuff first, fuel filter and lines should be checked, then spark. These have an in tank pump if it is the 1.8t or an in line pump next to the tank if it is a 2.0. Check the pressure regulator as well.
Mar 6, 2009 at 2:16 AM
