1997 Volkswagen Golf Engine Hesitates
70,000 MILES • 4 CYL • FWD • MANUAL
NELSON MEIRING
Hi There, i need help urgent please.
I've got a VW 2l 16v ABF in a VW MK1 Body.
There car has been hesitating now for 3 months.
It hesitates at 2000 - 2200rpm and 4800 - 5200rpm.
The Coil and the Fuel Management overheated.
Everyhing was checked. Injectors, Distributor, Coil, Plugs, Plug wires, Coil Wire, TPS, Fuel Pump, Vacuum Pipes, I've got a new Fuel Management System.
I'm at a loss, please help
May 5, 2010 at 10:26 PM
NELSON MEIRING
The only Sensor the car has is a TPS senser.
It does't have a Cat Converter.
Checked SPark Plugs, and wires.
Fuel Injectors were tested and Cleaned.
Got a Brand new FPR.
Timing is set correctly.
Brand New Plug wires and Coil wire.
Changed the Coil. Same problem.
Brand New Distributor, Cap and Rotor.
Same problem.
May 5, 2010 at 10:51 PM
