1996 Volkswagen Golf E brake light
141,000 MILES • 4 CYL • 2WD • MANUAL
JF76
My emergency brake warning light wont go on when I pull the lever, it does turn on when I start the vehicule and when I take the fluid reservoir cap off.
the switch looks fine, not stuck...
help me please
thanks
jf
Dec 20, 2009 at 6:27 AM
CROWD
  • 9 POSTS
youl need to take off all your plastic thing from your e brake and change the switch or better then that un-plug then switch start your car and take the 2 wire rub them towgeter and if your ligth of e brake go on its the switch if not well you know its not your switch
chris...
Dec 22, 2009 at 2:50 AM
