1996 Volkswagen Golf drain/refill oil
98,000 MILES • 4 CYL • FWD • AUTOMATIC
VIDGE
i have golf with a 2000cc motor it is an AGG egine code i am having problems with the gear box. i have replaced the oil cooler due to oil in the coolant. i have been unable to find any where to check/top the ATF fluid. there is no dipstick and no markings on the speedo drive. please help
Sep 8, 2009 at 8:23 AM
DUBTECH
  • 159 POSTS
There is an inspection plug located on the transmission pan. The ATF temp needs to be between 30-35 C, remove the inspection plug, then fill through the inlet on the front of the trans until fluid drips from the inspection hole. Re-insert inspection plug and replace the cap covering the inlet tube.
Sep 9, 2009 at 5:05 AM
