1996 Volkswagen Golf clutch problem
1996 VOLKSWAGEN GOLF
14,000 MILES • 6 CYL • FWD • MANUAL
GOLFGTIBLACK
recent new clutch,,,clutch peddle only has about 2 inch when pushed down it goes into gear with force my car drives but changing gear is a problem ,, car goes into all gears but not as easy as it should
Dec 29, 2009 at 6:25 AM
  • 31,937 POSTS
Hi there, Check that the hydraulics are ok, if fluid low this will be a leak at the slave or master cylinder, you will have to check for fluid under the rubber boots, if so replace and re bleed system.
Mark (mhpautos)
Dec 29, 2009 at 7:26 AM
