i have changed my car starter motor and now when i start the car is making noise?
Sep 7, 2008 at 10:28 PM
✓Experienced Mechanic
Hi there,
Can you be a bit more specific as to the type of noise, if you feel that is is starter related make sure that the starter is mounted correctly and it is the correct starter for your car, check for any damage on the Bendix drive and the ring gear teeth as the ratio may be incorrect.
