1992 Volkswagen Golf
92,000 MILES • 4 CYL • FWD • AUTOMATIC
DAYTRIPPER46
Hello, I have a 1992 VW Golf GL Auto Trans. I think I need to replace my starter because sometimes when you turn the ignition to start, it just whines because the pinion doesn't make contact with the flywheel. Is this a hard job? Thanks....
Oct 14, 2008 at 5:33 PM
  • 31,937 POSTS
Hi there,
The book time is just on 2 hrs to R & R the starter so there must be a bit involved, this may be a job for your mechanic i would get a quote first.
mark (mhpautos)
Oct 14, 2008 at 10:50 PM
DAYTRIPPER46
Thanks for that answer but I have already spoke to a couple of mechanics and they told me the same thing so I already know this. What I don't know is what is involved that takes 2 hours to replace a starter that mounts to the block with only 2 bolts and wires attached.
Oct 15, 2008 at 4:21 AM
  • 31,937 POSTS
Hi there,
going by the times guide it must be an access issue as the manual trans version take much less time, i have not done one my self so i am unsure, i will contact a few other mods and see if anyone has done one, as i will be away for a few days i will place the request now, so i hope that you will get an answer soon,
Mark (mhpautos)
Oct 15, 2008 at 9:17 AM
  • 31,937 POSTS
Hi there,
from what i have discovered, on autos you have to remove an engine mount and support the engine with a special tool, this will be the extra time factor involved. i hope this helps.
Mark (mhpautos)
Oct 15, 2008 at 11:40 AM
DAYTRIPPER46
Thanks a lot for your answer. It sounds logical. The best thing for me to do is to get under the car and check it out. Then make a decision whether to do it myself or to contract it out. I already purchased the starter. Your efforts are greatly appreciated.
Oct 15, 2008 at 4:21 PM
