1994 Volkswagen Golf how to?
MAXIMUM
Computer problem
1994 Volkswagen Golf 4 cyl Two Wheel Drive Manual
how can i make my fuel to air mixture more lean,do i need a sensor enhancer unit to run with hho for this or can i trick my computer to do this ? thanks . maxime lamoureux.
Jul 6, 2008 at 1:57 AM
BLACKOP555
  • 10,386 POSTS
you can choose to modify the maf sensor, the map sensor iat sensor. just about any sensor that adjusts the fuel to use less fu el and be lean.
but remember it will make the o2 sensor read lean and it will readjust the fuel.
then you have to eliminate the o2
lots of time to do all of this and money.
plus youll just make the engine run hotter and eventually burn up, along with have very very very little power.
Jul 26, 2008 at 2:42 PM
