1994 Volkswagen Golf gear 1 is becoming hard to access.
1994 VOLKSWAGEN GOLF
142,000 MILES • V12 • 2WD • MANUAL
CASPER
i seem to struggle to get to gear 1 even when the clutch pedal is down to the limit. is there any kind of fluid i should have for the clutch?
e.g brake fluid for the brakes
Nov 12, 2008 at 9:05 PM
  • 31,937 POSTS
Hi there,
You use the same fluid in the clutch, if the fluid is low, you will have to check for a leak at the master cylinder or the slave cylinder, have the transmission oil level checked as well and get a stall test done on the clutch by someone that known how to do it correctly, start here.
Mark (mhpautos)
Nov 12, 2008 at 9:10 PM
