1994 Volkswagen Golf
NIKKILOUISE18
1994 Volkswagen Golf 56000 miles
My car is struggling to gain speed from stationery. It also over revs while it gains speed. Once it gets to about 30mph it seems better.
Jul 28, 2010 at 8:58 AM
  • 75,988 POSTS
If the transmission is not slipping-see below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 28, 2010 at 2:19 PM
