1993 Volkswagen Golf
1993 VOLKSWAGEN GOLF
GREG4X4
car will turn over but will not start. there is fuel but no spark
Oct 4, 2009 at 6:40 AM
DUBTECH
  • 159 POSTS
First check for any fault codes in the control unit. Then check the coil for power (battery +), ground (battery -), and for a pulsed signal from the distributor.
If all those sources are good you're probably in need of an ignition coil.
Oct 9, 2009 at 10:27 AM
