I have bled the brakes 3 times. No air bubbles etc. were found. They are still spongy and every now and then has a serious flat spot where the brakes do not stop the vehicle at all and the pedal goes to the floor. After pumping once or twice (most times only once) the brakes then work as normal. The flat spot seems to happen only at low speeds (in traffic) This may be coincidental, but is not consistent.
I have checked for leaks and found none. I have also kept an eye on the fluid reservoir and no abnormal usage was noted.
Am I missing something?
Nov 18, 2008 at 6:26 PM
