1987 Volkswagen Golf ENGINE KNOCK AND HAS LOW OIL PRESSURE
1987 VOLKSWAGEN GOLF
79,000 MILES • 4 CYL • FWD • MANUAL
CHARLIEE
CHANGED OIL PUMP NO OIL PRESSURE AND ENGINE KNOCKS
Apr 4, 2009 at 12:58 PM
Sounds like you need a crankshaft kit to fix the oil pressure and knocking problems. Bottom line excessive engine bearings clearances
Apr 4, 2009 at 1:01 PM
WAYNEFRASER
  • 21 POSTS
[quote:c62b97add0="charliee"]Engine Mechanical problem
1987 Volkswagen Golf 4 cyl Front Wheel Drive Manual 79000 miles
CHANGED OIL PUMP NO OIL PRESSURE AND ENGINE KNOCKS[/quote:c62b97add0]
Don't run it with no oil pressure , I mean at all.
You'll ruin the engine .
May 9, 2009 at 1:07 PM
