1987 Volkswagen Golf ENGINE KNOCK AND HAS LOW OIL PRESSURE
1987 VOLKSWAGEN GOLF
79,000 MILES • 4 CYL • FWD • MANUAL
CHARLIEE
MEMBER
FOLLOW
CHANGED OIL PUMP NO OIL PRESSURE AND ENGINE KNOCKS
Apr 4, 2009 at 7:58 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Sounds like you need a crankshaft kit to fix the oil pressure and knocking problems. Bottom line excessive engine bearings clearances
Apr 4, 2009 at 8:01 PM
WAYNEFRASER
MEMBER
[quote:c62b97add0="charliee"]Engine Mechanical problem
1987 Volkswagen Golf 4 cyl Front Wheel Drive Manual 79000 miles
CHANGED OIL PUMP NO OIL PRESSURE AND ENGINE KNOCKS[/quote:c62b97add0]
Don't run it with no oil pressure , I mean at all.
You'll ruin the engine .
