2006 Volkswagen Fox Pedal Box Replacement
REDMEN1990
Brakes problem
2006 Volkswagen Fox 4 cyl Manual 50000 miles
Hi
A bracket snapped off the pedal box on my fox. VW replaced the complete pedal box part, but since they have returned the vehichle to me, the steering is not right and is pulling to one side. Is this something that could occur when they change the pedal box?
Sep 5, 2010 at 11:32 PM
  • 31,937 POSTS
Hi there,
I think that they may have had to remove the steering column, i would report this fault and add that it is only since their repair work it has been a problem.
mark (mhpautos)
Sep 5, 2010 at 11:38 PM
REDMEN1990
thanks. I rang earlier and they said it was nothing to do with the new part being put in and that it must have happened before or since and that i would have to pay £40 diagnostic charge and £177 to fix if an error is shown.
i feel like they are trying it on - the original job was done as a good will gesture because they messed up big time when ordering the new part so i feel like they are trying it on and trying to recoup some cost.
what you think?
Sep 6, 2010 at 12:03 AM
  • 31,937 POSTS
Hi there,
I would ring a different dealer and confirm if the steering column has to be removed to replace the pedal box, if so, you may have them cold.
mark (mhpautos)
Sep 6, 2010 at 12:12 AM
