Interior problem
1991 Volkswagen Fox 4 cyl Front Wheel Drive
my drivers seat belt will not retract. How can I fix it?
Monday, February 16th, 2009 AT 4:53 PM
BLUELIGHTNIN6
MECHANIC
Always have safety equipment repaired by a trained technician. Never perform safety equipment repairs yourself unless you are qualified to do so.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Monday, February 16th, 2009 AT 5:02 PM
BRASSMONKEY
MEMBER
I had the same problem once in a 92 wolfsburg fox of mine. Kept getting worse and worse The way they are placed in the car by the front seats allows for change from your pockets or other dirt an such to fall inside. Simply get a pair of needle nose pliers or slim medical hemostats and feel around in there. You will be supprised at how much dirt or coins it can hold. I found close to $3 in change in mine.
