1988 Volkswagen Fox wont stay running
1988 VOLKSWAGEN FOX
PERRYD
Engine Mechanical problem
1988 Volkswagen Fox 4 cyl Manual 140000 miles
Hi i have a 88 vw fox. It starts no problem however it will not stay running, it stays running only if i keep pressing gas i have changed fuel pump on it so its getting enough fuel. Spark plugs are good. I reallly dont know what else to look at i would really appreciate if you could help me.
thank you
Jun 29, 2009 at 7:12 AM
BRASSMONKEY
  • 12 POSTS
One reason could be idle adjustment issue. Another could be dirt in the fuel line or air. Try blowing fuel line out from each end with an air hose from air compressor, it will need at least 60psi to do the job.
Oct 19, 2009 at 3:59 PM
