I snapped my clutch cable. I have bought a new one and it matches the old one exactly. I can feed it through the fire wall and attach it to the pedal and can attach it to the clutch fork but it will not go into the bracket correctly. The fittings with the thread, nuts and washers to secure it to the bracket are down further than they need to be. If I attach one end to the pedal and hook up the fittings and nuts and bolts in the bracket, the bottom end will not reach the clutch fork. I cannot pull the cable out any further to make it reach. Both parts match and are exactly the same so what am i missing? Also, I have routed it exactly the same as it was before.
Jun 3, 2010 at 8:29 AM
