1987 Volkswagen Fox starting
WOODSIDE
Electrical problem
1987 Volkswagen Fox 4 cyl Two Wheel Drive Manual
Turning the key does not engage the starter, the interiour lights come on and the horn sounds but it wont start any ideas where I should begin?
Aug 11, 2009 at 3:00 PM
BRASSMONKEY
  • 12 POSTS
Sounds like you may have a bad starter solenoid. But check to make sure the ground or positive wire to the starter isn't just loose 1st. If not, take the starter off and have it checked out. The solenoid is a cheaper fix that getting a new starter. But you wont know until you do.
Oct 19, 2009 at 3:54 PM
