2002 Volkswagen Eurovan Malfunction Indicator Lamp came on
2002 VOLKSWAGEN EUROVAN
40,000 MILES • 6 CYL • FWD • AUTOMATIC
GBCRAFT
Along with the indicator lamp coming on and remaining on, the transmission selector lever positions indicator appear bright against a dark background at the same time. My book tells me there is a malfunction in the transmission and the transmission has gone into the "Auxiliary Mode".
Question - is it possible that these two problems could be related?
What is the fix for these problems?
Will I be able to preform the work myself or does it require a specialist?
If so, how much should I expect to pay?
I thank you.
GBC
Oct 18, 2010 at 12:08 PM
What you need to do here is have the PCM and TCM scanned code/s this is your starting point finding out what's going on.
Oct 18, 2010 at 1:21 PM
