2002 Volkswagen Eurovan Ignition Lock Cylinder
111,000 MILES • 6 CYL • FWD • AUTOMATIC
JCOLOMBO86
Our ignition lock cylinder appears to have failed. To remove the screws seem to be a specialty 3 pronged head which I am unfamiliar with. Does anyone know what type of tool I need to remove the screws? Secondly, the black plastic rim around the key insert cylinder has what appears to be an electrical connection attached. Is this removable? If so what is preferred method?
Sep 17, 2009 at 4:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Proper replacement procedures for your vehicle's ignition lock cylinder are below.. REMOVAL: Turn the ignition switch to the LOCK position. Disconnect the negative battery cable. Wait 10 minutes for the battery back-up power to discharge. Remove the air bag unit and steering wheel. Remove trim below steering column switch. Remove trim above steering column switch. Detach the connector from the steering column by pulling in direction of the arrow, shown in the accompanying illustration.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_979.jpg
Disconnect harness connectors to signal and windshield wiper switch. Unfasten the mounting bolts, then disconnect signal and windshield wiper switch from steering column
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_274.jpg
Disconnect harness connector from steering lock housing. Drill out mounting bolt for steering lock housing. Install hex nut on steering column to secure steering wheel. Remove clamping washer. Pull off steering lock housing from steering column tube and steering rod tube. INSTALLATION: Set steering lock housing in place and lightly tighten using new snap-off screw. The remainder of installation is the reverse of the removal procedure.
Sep 17, 2009 at 10:01 AM
JCOLOMBO86
Thank you bluelightnin6!
Sep 17, 2009 at 10:24 AM
REEFRANGER
Were you able to replace the lock cylinder with these instructions? Where did you get a lock cylinder?
Jan 14, 2011 at 6:09 PM
