2001 Volkswagen Eurovan Oil smells like gas when I pulled o
2001 VOLKSWAGEN EUROVAN
64,000 MILES • 6 CYL • FWD • AUTOMATIC
BABYFEETKB
Oil smells like gas when I pulled out dipstick. Can you tell me what might be the problem? Car also smells like exhaust when running.
Thanks
May 17, 2009 at 5:59 PM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
May 17, 2009 at 6:05 PM
BABYFEETKB
Do you think there might be a blown head gasket? The gas smell is strong when dip stick is pulled from oil.
May 17, 2009 at 6:11 PM
If its a headgasket problem you'll be experiencing overheating check the stuffs I've mentioned and comeback with some results so we can continue.
May 17, 2009 at 6:19 PM
BABYFEETKB
Thank you. I will do that and get back to you later.
May 17, 2009 at 6:28 PM
