2000 Volkswagen Eurovan Starter
2000 VOLKSWAGEN EUROVAN
VLASTIMIL BAZANT
Engine Mechanical problem
2000 Volkswagen Eurovan 6 cyl Front Wheel Drive Automatic
I started the engine. Nothing unusual happened, however within about 30 seconds the starter engaged by itself. I turned off the engine, raised the hood and looked for signs of trouble. Did not see anything,but there was a faint smell of electric insulation .Tried to started again. The engine started immediatelly, the starter disengaged correctly only to engage by itself in a minut or so. Turned off the engine. Than the starter engaged on its own. I disconnected the battery and I don't have a clue where to start. Would you please comment ? Thank you Vlastimil.
Nov 29, 2009 at 9:21 PM
  • 31,937 POSTS
Hi there, there is a park/starter relay behind the center of the dash, i would be checking this out as also the ignition switch, there is not pic of the location of this relay on the data base sorry.
mark (mhpautos)
Nov 29, 2009 at 10:43 PM
VWSCOTT
  • 66 POSTS
i think that relay is located on the left lower corner of the relay panel. i think they had recall on those switches. if it's all white throw it out and get a new one. they're only $20 or so at the dealer, used to be anyways.
Jul 7, 2012 at 1:35 AM
