Transmission problem
1984 Volkswagen Eurovan 4 cyl Two Wheel Drive Manual 234K miles
When shifting into 1st or 2nd gear the vehicle will not respond.............
When shifting into 3rd or 4th gear the transmission is active and works. Reverse is active. The new clutch has only 30k miles.
What could cause the problem and can it be repaired ? Are transmission parts still available for a vehicle this age. Would fixiing this problem be expensive......
Please advise.... Thank you, Thomas paka99@yahoo.com
Dec 29, 2007 at 3:37 PM
