1990 Volkswagen Corrado Car wont start
1990 VOLKSWAGEN CORRADO
127,000 MILES • 4 CYL • FWD • AUTOMATIC
MR.VOLKSWAGEN
The car started once but will not start now it does turn over. what do u think the problem could be? it is a g60 supercharged 4cly.
Apr 16, 2010 at 3:10 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 16, 2010 at 5:58 AM
