2002 Volkswagen Cabriolet check engine light
2002 VOLKSWAGEN CABRIOLET
81,200 MILES • 4 CYL • 2WD • MANUAL
DCFMKYN
When I fill my tank up the check engine light comes on. When the tank gets to less then half full the light goes off; this happened once. Other times it stays on. I check the cap and its on tight. Could it be the type of gas? The car runs fine..is this serious??
Nov 9, 2010 at 10:16 AM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Nov 9, 2010 at 5:21 PM
