1998 Volkswagen Cabriolet it doesnt starts
123 MILES • 4 CYL • 2WD • MANUAL
AXIT
when i press the clutch and try to start my car it doesn't starts. i happened 1 yr ago but it started later by it self but now it doesn't start. it doesn't make any sound of cranking or anything like that. i checked the battery its all good. i guess the problem is with the starter but i m not sure..........can some one help me with it thank you
May 24, 2010 at 4:02 AM
  • 75,988 POSTS
Try shorting out the starter solenoid to engage the engine if it does-inspect and test the clutch switch.
May 24, 2010 at 10:38 PM
