1995 Volkswagen Cabrio ecm blocked?
16,000 MILES • 4 CYL • FWD • AUTOMATIC
POLOCOACHKEVIN
My check engine light is on. My mechanic says that he cannot get a code because the ecm has "blocked access". What can we do to get into the ecm and get the code?
Aug 7, 2009 at 8:01 AM
  • 31,937 POSTS
Hi there,
Make sure that the scanner is compatible with the car, maybe try a VW scanner first, if this is not successful, get the ECU tested for internal faults.
Mark (mhpautos)
Aug 7, 2009 at 12:11 PM
