1983 Volkswagen Cabriolet engine miss
BIGAL1124
Engine Performance problem
1983 Volkswagen Cabriolet 4 cyl All Wheel Drive Manual
my 83 1.8 cabriolet was ideling when it started missing at idle and under load i cked spark ok compresion 90lb i replaced injector no help any ideas thanks
Oct 13, 2010 at 1:26 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Oct 13, 2010 at 2:41 PM
