2002 Volkswagen Bora VW Bora - Air Conditioning problems
2002 VOLKSWAGEN BORA
LETHAL29
2002 Volkswagen Bora Two Wheel Drive Manual 88000 miles
Hi there,
I’m hoping you can help with an air conditioning issue I have recently had with me VW Bora.
I’ve noticed over the last couple of days when I start the car that there is a strange bubbling or flowing noise coming from the engine, which I didn’t really pay much attention to, as I’ve just bought the car and still getting used to its various noises etc.
I found last night that when I was driving, the car would make a chirping noise, and do a little shudder, almost as if it was cutting out.
I stopped at a garage to ask for directions and asked the guy if he knew what the noise could be – he asked if the air-con was on and said it was probably the compressor.
As soon as I turned the air-con off, the noise and the shuddering stopped, so I’m guessing he was right.
Any ideas what the problem could be?
Is this something that I could investigate and/or fix myself, or does it need to be looked at by a mechanic?
Thanks for your help.
Jun 4, 2010 at 6:13 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
if this is an A/C related problem, this should be investigated by a qualified tech as there will be special testing equipment and it may involve working dangerous high pressure refrigerant, leave this to the pro.
mark (mhpautos)
Jun 4, 2010 at 9:00 AM
