2001 Volkswagen Bora
VILLESHER
Engine Cooling problem
2001 Volkswagen Bora 4 cyl Two Wheel Drive Automatic
my fans continue running long after I turn the engine off
Feb 26, 2010 at 2:50 PM
  • 31,937 POSTS
Hi there,
VW cooling fans as a rule will keep running after the car is switch off if the coolant temp is above the trigger point for the fan sensor, if you are having no cooling system problems, you may have a faulty fan sensor, have this checked out first'
mark (mhpautos)
Feb 26, 2010 at 2:53 PM
