2006 Volkswagen Beetle stalls while idle
57,500 MILES • 4 CYL • FWD • AUTOMATIC
KWHODGES
My car has suddenly started stalling while sitting idle (such as at a stop light). It would re-start, but only after 10-12 attempts. The engine sounds like it wants to turn over but just doesn't.
I took it into the dealer and they tested it (transmission, battery are 2 things I remember them mentioning) and said everything passed. I added a fuel additive to the gas tank in case I had some bad gas or water in the tank. Car ran ok for a few days, but all in-town driving. This morning while on the interstate it suddenly went from 65 to 40 and wouldn't drive any faster. It then stalled while I was in motion. The car did restart but I don't know if it would drive over 40.
Help. I don't know what to check or try next.
Jun 6, 2010 at 9:32 AM
  • 75,988 POSTS
Hi kwhodges, Welcome to 2carpros and TY for the donation
Get the throttle drive ( Electronic power control ) and throttle position sensor and mass airflow sensor tested.
Jun 6, 2010 at 11:18 AM
KWHODGES
[quote:064c2fc2e7="rasmataz"]Hi kwhodges, Welcome to 2carpros and TY for the donation
Get the throttle drive ( Electronic power control ) and throttle position sensor and mass airflow sensor tested.[/quote:064c2fc2e7]
I talked to the dealer again this morning and he said these were checked as part of the engine check and did not give a fault code. Any other suggestions?
Jun 7, 2010 at 2:58 AM
  • 75,988 POSTS
Possible causes below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 7, 2010 at 4:59 AM
