2006 Volkswagen Beetle Headlight
32,000 MILES • 4 CYL • 2WD • AUTOMATIC
LIFEISGR8
could you please give me the steps to replace the blub in my drivers side headlight?
thank u in advance for your time and assistance.
Aug 28, 2009 at 1:57 AM
DUBTECH
  • 159 POSTS
There is a lever and a clip that is accessible from the engine compartment.
You'll need to push down on the lever while pushing in the tap. The lever is connected to a spiral channel that will push the headlight assembly out as it turns. Sometimes the assembly will stick and need a little coaxing to wiggle it out.
Once the assembly is out you can remove the cover from the back and access the bulb.
Aug 31, 2009 at 5:56 AM
