2006 Volkswagen Beetle coolant light comes on
21,500 MILES • 4 CYL • 2WD • AUTOMATIC
JOEJSIN
My coolant light comes on and then goes off after I have been driving for about 1 minute.Why? Do I need fix it?
Jun 9, 2010 at 1:30 PM
2CARPRO JACK
  • 11,533 POSTS
Does it stay on or go back off? Does it ever come back on the go off while driving later in the day? have you checked the coolant level to be sure itis full?
Jun 9, 2010 at 1:54 PM
JOEJSIN
[quote:a9382cfa4d="2CarPros Jack"]Does it stay on or go back off? Does it ever come back on the go off while driving later in the day? have you checked the coolant level to be sure itis full?[/quote:a9382cfa4d]
It go back off after 1 min.
It never come back on the go off while driving later in the day. but, it be back on if I stop car over 2 hour.
I checked the coolant level. It higher than the min level line.
Jun 9, 2010 at 2:15 PM
2CARPRO JACK
  • 11,533 POSTS
If the level is good it is probably a bad coolant level sensor.Check to be sure the connections are good on the plug, otherwise it is probably the sensor
Jun 9, 2010 at 3:14 PM
