2004 Volkswagen Beetle Shifting hard and neutrals out durin
2004 VOLKSWAGEN BEETLE
74,000 MILES • 4 CYL • FWD • AUTOMATIC
CHARLES CATHEY
I have already replaced complete valve body thinking this was the problem. Exact same problems exist. Please give me some suggestions on what to check next?
Oct 31, 2010 at 10:47 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
Is the car storing any fault codes ? if not from the symptoms you describe you have bad clutch plates and they will need replacing .. any electrical fault on a transmission (including valve body)will usually set a fault code .. all other faults will not .. your best bet may a good transmission shop to diagnose the fault for you ?
Nov 1, 2010 at 9:17 PM
