2004 Volkswagen Beetle Headlights
JQOE04
Electrical problem
2004 Volkswagen Beetle 4 cyl Two Wheel Drive Automatic
Looking to change headlamp bulb, do not see obvious method of accessng bulb, don' t want to tear into it the wrong way. Never run into a problem with this nkind of simple maintenance before.
Thanks if you can help.
Aug 22, 2010 at 8:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Pull the lever to open the hood inside the left side under your steering wheel.
There is a black plastic lever on the column to the Passenger's side view same on the Driver's side.
Push it so that it "loosens" the column holding the light casing.
Gently push the column forward to get the entire casing for the headlight bulb out.
Unhook the wires attached to the light.
Take the light out on a table and unclip the black tab.
Unhook the clips on the side of the casing, and then the wire clip holding the bulb. (Close the clip the same way you opened it) .
Touch only the metal part or use a paper towel to hold the new headlight bulb (The oils from our hands will make the halogen bulb not last as long.)
Reverse the process for installation.
Aug 22, 2010 at 8:19 AM
